Old 07-20-2016, 03:03 PM   #6
Todd Gross
Liked 54 Times in 24 Posts
Default Re: 302 SBF Dart block potential cooling system issue
Originally Posted by Maverick View Post
Curious, does the block and heads have steam holes, do you run a alternator? Just don't trust electric instruments, when strange things are going on.
Yes the Dart Block has steam holes in the same location as the OEM block. I used Cometic head gaskets where the previous were Fel Pro. Both Head Gaskets have the steam holes and passages in the same, and I would say, proper locations.
The sensor was in the left front corner of the intake manifold. For a test we moved it to the left rear corner of the intake. It does not have a coolant cross over in the rear, but was in the coolant passage. No difference in the data log.
Yes on the alternator.
Todd Gross is offline   Reply With Quote
