Liked 455 Times in 147 Posts
SB 350 Stocker 12 Bolt. TH 200 Transmission, with Caltrac bars and Mono Leaf springs. What would be the proper Pinion angle to start with
![]() Thks for the Help ![]() |
Liked 162 Times in 45 Posts
Some is good, a little more is better. More is better. If you have trouble hooking the driveshaft it, it mite be too much. Dont be bashfull!
Liked 169 Times in 53 Posts
I run 3 degrees down on ours.
Bill Bogues 4696 STK |
Liked 113 Times in 9 Posts
6 degrees here in NY
Joe DeMarzo 1317 STK |
Its at .06 now. Was going to install 2 degree wedges to start but maybe I should install the 4 degrees and see if it likes it to start. Anybody play with a pyrometer readings at the U joints?, checking temps with Pinion angle changes to determine best angle. Thinking is, closer the angle is under a load, the less heat is being generated by the U joint as it rotates.
Liked 2,487 Times in 698 Posts
Just a couple or three degrees in Boulder City works great.
Liked 33 Times in 17 Posts
Call Travis at Calvert racing.
