Old 10-08-2018, 12:13 PM   #13
Jim Caughlin
Liked 808 Times in 247 Posts
Default Re: NHRA amended rollbar / cage rule
Originally Posted by Lyn Smith View Post
In the lower class Stockers you can run a 50 year old set of seat belts, but you can not run a set of aftermarket seat belts that are outdated by one day.Go figure.
I had a conversation earlier this year with our div tech director at the Seattle div race, he said that you can run out of date seat belts in any application where a roll bar//cage is not required. In this particular case, the racer had installed a roll bar in a lower classed stocker that did not require the bar. In that case, he does not need to comply with the harness date issue. As I said this came directly from our div tech director.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
