Old 10-25-2018, 04:34 PM   #11
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Driver ejection,NHRA cover up at St. Louis
Now wait a minute, if you are past the finish line and cross the "center line out of control" in a fuel car, you still win the race. And that also goes for hitting the guard wall, exploding your car apart, hitting the driver in the other lane or, oh yeah, smoking the tires.
Nothing that you have stated here is incorrect. However, Section 2 Page 9 of the 2018 NHRA Rulebook specifically notes that boundary infractions past the finish line will be enforced if they determine that excessive braking was the cause of the infraction. Capitalization is in the rulebook; not mine:
Anytime it has been judged that excessive braking has resulted in loss of control that results in contact with the guardwall and/or light fixtures or crossing the center boundary lines, INCLUDING PAST THE FINISH LINE, the contestant will be disqualified.
S/ST 51
S/C 53
Old 10-25-2018, 05:46 PM   #12
Bruce, welcome to the forum.
Have to say..it looked bad on video. crossing into the opponent's lane, even after the traps...Not good.
I was excited and put it in reverse is probably not a good case.
I'm afraid you'll just have to chalk this one up to experience. IMO
Old 10-25-2018, 06:01 PM   #13
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
This was obviously WAY past the finish line and not a case of excessive braking. I've had opponents hit reverse by accident in the shutdown area more than once. (once in eliminations, once in a qualifying run) On the elimination run, I got beat fair and square. I didn't complain, and my opponent busted his ***** to swap transmissions between rounds and continued on in eliminations, albeit on some slightly less than perfectly round tires.
A little common sense goes a long way.
Old 10-25-2018, 06:27 PM   #14
Lenny5160
Lenny5160's Avatar
I completely agree, but it depends on how closely the powers that be are watching and paying attention.
If you're in the tower eating a sandwich, and you hear Alan say "whoa!" which makes you look up and see smoke and a car crossed-up shortly past the finish line, it is probably easy to make the bad assumption here.
And no, I don't think any assumptions should ever be made in these cases. But we also know how much of a priority we can be in the NHRA world.
S/ST 51
S/C 53
Old 10-25-2018, 07:19 PM   #15
HR9121
HR9121's Avatar
I'm not saying the right or wrong decision was made but when's the last time they reversed a decision on anything. I think they are taught to make a decision and stick to it, just my opinion. When I watched the video, I can see why he made the call to the top end to DQ him.
James Williamson
W200 J/SA. SS/JA
Old 10-25-2018, 07:58 PM   #16
Mike Fuller
Liked 198 Times in 79 Posts
That is correct. Seems like the rules are different for this case. I have also seen certian racers smoke the tires during excessive braking on two consecutive rounds an only get a warning.
Mike Fuller 396 STK
3961 SS
Mike Fuller is online now   Reply With Quote
Old 10-25-2018, 09:06 PM   #17
FED 387
Liked 333 Times in 180 Posts
After watching the video many times I feel the call was correct---My reasons are that the car did not "just smoke the tires a teeny little bit " but locked them up enough to disrupt the forward motion of the vehicle and cause the car to change lanes violently and at one point 100% of the car is in the other lane---It appears that he "lost control" and fortunately did not hit something whether it was another car or the wall--This is way beyond just smoking the tires by "excessive braking" --The driver openly admitted he put the trans into reverse or something of the sort something about his shifter ---The call was a safety issue and was meant as a punishment or deterrent not to do this again---I don't care if he was excited about the fact that he was going to the 5th round in stock that caused him to do this.He was wrong and I feel the decision is correct--- who the division director is or how long he has been the division director should have no bearing on the decision----The offender is wrong, it was the correct decision at the time , after either observing it in person or on a video rerun. You cannot convince me otherwise. I feel the DQ was correct. FED 387
Old 10-25-2018, 09:17 PM   #18
I was just going to make that point. To expound on it then, the DD DQ's him. They then tell the guy who was out, that he's in. Then the first party goes to the tower to make their case.
20 min. later the DD would have to say okay, you're in. Then he has to tell the guy who was out, then in , that he's out again, because all the other guy did was put it in reverse after the finish line , smoke the tires ,and cross over into his lane.
I've been around NHRA long enough to tell you it ain't gonna happen.
Old 10-25-2018, 09:41 PM   #19
Dan Lattimore
Liked 154 Times in 37 Posts
Originally Posted by mark yacavone View Post
i was just going to make that point. To expound on it then, the dd dq's him. They then tell the guy who was out, that he's in. Then the first party goes to the tower to make their case.
20 min. Later the dd would have to say okay, you're in. Then he has to tell the guy who was out, then in , that he's out again, because all the other guy did was put it in reverse after the finish line , smoke the tires ,and cross over into his lane.
I've been around nhra long enough to tell you it ain't gonna happen.
nope
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 10-26-2018, 09:00 AM   #20
pmrphil
Liked 348 Times in 152 Posts
The most important question is: was he/it out of control? Yes. Was it caused by excessive braking? No. BUT it was that action that endangered another racer (and himself) and should have been tossed, it really doesn't matter that it wasn't caused by braking, the point is he was OUT OF CONTROL and dangerous. Fix the shifter problem and go on. Lots more races to win, only one life to lose.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
