Old 09-18-2019, 12:31 PM   #11
B Parker
Liked 2,343 Times in 465 Posts
Default Re: Attention Nova 350/255 stock combo.
Originally Posted by GEORGE PETERSON View Post
Almost every combo is capable of running 1.20 under? Well my combo is a 302/309 HP (1.02 HP per cu. in.) and I can't. But there's a 350/320 HP (.91 HP per cu.in.) in my class that can. Same heads, compression, carb. cam as my combo, but with one exception. 48 MORE CUBIC INCHES! If my combo was factored at .91 HP per cu, in. I could loose 322 lbs. Then I could run 1.20 under. I guess I'm not spending enough money and time.
George Just because you can't make it run that fast doesn't mean someone else couldn't. Also sounds like the person that picked the 350/320 combo knew what car to build for the class. How about this. Anyone that runs your class should get HP just so you can be even with them. What do you think? Barry
