Old 10-04-2019, 07:33 PM   #1
Ralph A Powell
Liked 225 Times in 136 Posts
Default Re: Clutch ID
It's a long style hays thick cover fingers from the large circle appear to for the large Ford throw out bearing for the 13/8 input shaft
Originally Posted by chopperloco View Post
Clutch ID
Going to try to post a pic...
Does anyone recognize this clutch?
it's going in front of a Doug Nash 5 speed crash box, behind a small block in a 65 Vette,not positive which release bearing to use..
https://www.facebook.com/photo.php?f...oqSEUAlK&ifg=1
Old 10-05-2019, 12:48 AM   #2
Rory McNeil
Liked 1,103 Times in 301 Posts
Its actually called a Borg&Beck/Long hybrid. The Long fingers are installed in a Borg & Beck cover, and I believe rather than use the Longs counterweighted fingers, they used the Borg & Becks roller counterweight inside the cover. I never ran one, but I understand the Long style forged levers have a faster ratio than the B&B versions stamped steel levers.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 10-05-2019, 06:36 AM   #3
Maverick
Liked 36 Times in 26 Posts
I have a couple of these pressure plates, in my collection of clutch parts. This pressure plate was conceived on some poor thinking. I would look for something with new technology. A lot of things have changed in clutches, . Be careful if you use this clutch, especially with the clutch material, rag or sintered iron. Do , some research, but the clutches have changed over the years, and this clutch was made with old thinking. Good luck
Old 10-06-2019, 01:48 PM   #4
chopperloco
chopperloco's Avatar
Liked 82 Times in 23 Posts
WOW!!!
Thanks for all the great info men!
I'm even more confused now lol
The disk is sinitered iron,the complete clutch came with the Nash crash box(no syncros)
The car is an ex-Modified 65 vette with a high comp.ratio tunnel ram 355"
It will see a little street driving to local cruise nights/car shows and a few visits to the strip.
I'm trying to work with all the old crap that i have on hand on a somewhat limited budget(as crazy as that sounds)
chopperloco is offline   Reply With Quote
Old 10-06-2019, 02:34 PM   #5
weedburner
Liked 20 Times in 16 Posts
For what you want to do, just use the parts you have and add a ClutchTamer to the mix. Not only will the car be far less likely to break parts, but also very likely to be quicker than it was before.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 10-06-2019, 06:50 PM   #6
Chevy55
Banned
Liked 179 Times in 89 Posts
It's really going to be tough running that crash box on the street, I'm interested in your thoughts after you get it going.
Chevy55 is offline   Reply With Quote
Old 10-06-2019, 08:45 PM   #7
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
It may be worth a shot to give Roy Storey a call. He was the clutch guy at Hays for years. I’m sure he could do something with it. His number is 216-333-4900. Mention my name if you call him. Good luck with the project!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 10-07-2019, 02:05 PM   #8
Rod Greene
Liked 242 Times in 81 Posts
Back in the day every thing had a crash box. No semi truck trans had synchros. You just have to know how to drive.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
