#11 |
Liked 880 Times in 311 Posts
This was with a 904/Proflite. I made the change in my V-6 car from a well prepared 1.98 PG and 7" converter combination. The first ratios I chose were not best for the 3 speed, but I didn't want to over do it and I used the same converter. 2.12/1.35
3185 lb car it picked up a little more than a tenth. Most of it because of the second gear (no fall back). I then went to a 2.45/145 and got another .08. Then I changed converters and picked up another nickel. The first test was a back to back at the track. The converter change was at the track..so easy to change ratios and simple. I'm sold on them. I have several gear sets and am about to pull the trigger on a turbo 350 version.
Adger Smith (Former SS) |
#12 |
How much is a pro trans with a brake?
#13 |
It depends on how much lightweight stuff you put into it.
I have bought over a dozen transmissions from them and they have been always very fair. you buy the best and you only CRY ONCE!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 08-22-2020 at 03:27 AM. |
#14 |
Liked 203 Times in 52 Posts
How does the metric 200 compare to the pro trans?
Thanks
The more people I meet the more I like my dog Kevin |
#16 |
Best Trans I have owned. Custom gear ratios available as well.
Picked my car up 4 to 5 hun over my previous T350. Back-to-back tested, same day, during a track rental test session. Been very reliable.
Ed Wright 4156 SS/JA |
#17 |
Liked 30 Times in 16 Posts
Thi
#18 |
Liked 68 Times in 41 Posts
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#19 |
I believe that some of the ratios are more efficient than
other ones = It was explained to me by one of top West Coast transmission builder.
#20 |
John,
I have one of those charts, if it doesn't load correctly let me know I think it is called reaction carrier efficiency. It is expressed like : 1.04 Not as efficient as .66 adgersperf@aol.com I will e-mail it. Front Planetary Sun/Ring Rear Planetary Sun/Ring AA 24/80 1 44/70 A 28/80 2 38/70 B 28/70 3 28/62 C 28/62 4 28/70 D 38/70 5 36/62 E 36/70 6 36/70 F 28/58 7 28/58 G 44/70 8 55/80 H 36/62 Dave Smith Pro Trans Racing @ProTransRacing1 1stgear 2ndgear Front/Rear Reaction% 1stgear 2ndgear Front/Rear Reaction% 1.73 1.3 AA-8 0.83 2.39 1.51 E-5 0.71 1.78 1.30 AA-1 0.89 2.40 1.40 B-4 1.04 1.81 1.30 AA-5 0.95 2.40 1.54 D-1 0.66 1.85 1.30 AA-2 0.99 2.41 1.48 F-6 0.80 1.86 1.35 A-8 0.77 2.42 1.58 H-8 0.59 1.88 1.30 AA-6 1.03 2.45 1.45 C-3 0.90 1.90 1.35 A-1 0.83 2.45 1.51 E-2 0.75 1.92 1.30 AA-7 1.07 2.47 1.54 D-5 0.69 1.95 1.35 A-5 0.86 2.48 1.48 F-7 0.83 1.96 1.30 AA-3 1.12 2.50 1.58 H-1 0.63 1.98 1.40 B-8 0.73 2.51 1.51 E-6 0.77 1.99 1.35 A-2 0.92 2.53 1.48 F-3 0.87 2.03 1.35 A-6 0.95 2.54 1.54 D-2 0.73 2.03 1.40 B-1 0.78 2.54 1.63 G-8 0.57 2.05 1.30 AA-4 1.21 2.56 1.51 E-7 0.80 2.07 1.35 A-7 1.00 2.57 1.45 C-4 0.97 2.09 1.40 B-5 0.82 2.58 1.58 H-5 0.66 2.10 1.45 C-8 0.69 2.59 1.54 D-6 0.74 2.12 1.35 A-3 1.04 2.63 1.51 E-3 0.84 2.13 1.40 B-2 0.86 2.63 1.63 G-1 0.60 2.16 1.45 C-1 0.73 2.64 1.58 H-2 0.69 2.18 1.40 B-6 0.88 2.66 1.54 D-7 0.77 2.18 1.48 F-8 0.66 2.68 1.48 F-4 0.93 2.22 1.35 A-4 1.12 2.70 1.58 H-6 0.71 2.22 1.45 C-5 0.77 2.71 1.63 G-5 0.63 2.23 1.40 B-7 0.92 2.75 1.54 D-3 0.80 2.24 1.48 F-1 0.70 2.78 1.51 E-4 0.89 2.25 1.51 E-8 0.64 2.78 1.58 H-7 0.74 2.28 1.40 B-3 0.96 2.78 1.63 G-2 0.66 2.28 1.45 C-2 0.80 2.85 1.63 G-5 0.68 2.30 1.48 F-5 0.74 2.86 1.58 H-3 0.77 2.32 1.51 E-1 0.68 2.89 1.54 D-4 0.86 2.32 1.54 E-1 0.62 2.93 1.63 G-7 0.70 2.33 1.45 C-6 0.83 3.02 1.63 G-3 0.73 2.36 1.48 F-2 0.77 3.03 1.58 H-4 0.82 2.38 1.45 C-7 0.86 3.20 1.63 G-4 0.78
Adger Smith (Former SS) Last edited by Adger Smith; 08-22-2020 at 04:56 PM. Reason: Sorry it won't load the spaces between colums |
