Liked 20 Times in 15 Posts
I've seen this mentioned before. In an A body, that Q or R. This combo better in T? I remember Clayton had a killer 273-2 wagon. Very well flogged. 318 a better, maybe cheaper route?
Instead of posting on here asking about how "good" all of these "good" Mopar combos are, why don't you try actually building one. If you really know as much about Mopars as you seem to then you shouldn't have to ask. You surely don't need my permission.
Liked 520 Times in 176 Posts
Good morning, is the 2 bbl carb bigger for the 318 engine combo or is it the same size as the 273 engine combo? That should be the question that needs to be addressed here. Here's an example the 327/ 275 hp engine uses the same size Q-Jet as the 350/255 hp engine combo. The 327 engine would "see" the same carb as slightly bigger because of the slightly less demand the smaller cubic inches puts on the carb. Along with other important engine specs, that's something I look at as well while "brain storming " a new race combination. Just my two cents.
Henry, the 318-2V combo is pretty good. I'm just trying to instigate this guy actually DOING a combo for once instead of just TALKING about how good they are.
Liked 805 Times in 341 Posts
Isn't the 273 factored with more horsepower than the 318?
Anyone know the history on that? Thanks! |
It depends on the year and the heads. 273s are between mid 160s to mid 170s and the 318s are from high 160s to mid 180s.
Liked 974 Times in 310 Posts
Billy i think you should step up and build a mopar........lmao
Short block in the car. Waiting to find either an appropriate 2 or 4 bbl carb and intake. Hell Billy!, you really screwed things up with the 273 aluminum intake hissy fit. That intake made a lot of HP for me.
#10 | |
I believe the car featured is Kevin Leinart's. https://www.facebook.com/groups/1447...ment&ref=notif |
