Old 04-21-2021, 08:40 PM   #1
bestephen
Default GM 12 Bolt - Racepak Drive Line Sensor Bracket
Is anyone running a Racepak driveline sensor on the GM 12-bolt? Looking for some ideas for the mounting bracket
bestephen is offline   Reply With Quote
Old 04-21-2021, 09:05 PM   #2
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Re: GM 12 Bolt - Racepak Drive Line Sensor Bracket
About 6" long piece of angle aluminum stock with 2 holes through the web of the 12 bolt to mount it. A slight twist put into it with and pair of adjustable wrenches.
Old 04-21-2021, 09:06 PM   #3
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
I was going to mount on the yoke but would had to remove
And machine a surface for the ring
I just mounted the ring on the Tran yoke and the pickup
Off the tail shaft web. Works good.
I running a metric 200 trans
David
Willyracer is online now   Reply With Quote
Old 04-22-2021, 12:56 AM   #4
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
I built a mount, drilled holes in the webing and mounted there. I still have template I can post tomorrow
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 04-22-2021, 04:59 AM   #5
J&S Racing
Liked 319 Times in 82 Posts
Old 04-22-2021, 08:58 AM   #6
rod butcher
Liked 132 Times in 27 Posts
David
Thats how I did mine also.
rod butcher is offline   Reply With Quote
Old 04-22-2021, 11:24 AM   #7
curtis reed
Liked 125 Times in 59 Posts
This is on a Dana but the same idea I applied on my 12 bolt. Just made the aluminum piece a little cleaner. That one we made in a hurry and is the only pic I have. Then a small angle bolted on for the sensor.
curtis reed is offline   Reply With Quote
Old 04-22-2021, 11:33 AM   #8
Jim Kaekel
Liked 535 Times in 110 Posts
I've made a couple, one for my son's and for my own car, both for 12-bolts. Similar to what Rich B. above says, I used a piece of 1/4" thick x 1" wide 90° angle aluminum x about 6" long. Drilled a pair of 1/4" holes through the webs for mounting. Mine are certainly not CNC quality but I think as long as the sensor winds up .050"-.100" from the split collar, you're alright.
Jim Kaekel 3836 STK
Old 04-22-2021, 02:21 PM   #9
bestephen
Originally Posted by J&S Racing View Post
I like how clean this looks, Is there a special welding procedure for welding to the cast iron casing?
Old 04-22-2021, 03:24 PM   #10
J&S Racing
That I can’t answer, I had Mark Markow do this for me. I will say the collar had to be machined down to fit the yoke.
