Looking for any info on an old sbc Cam Dynamics roller cam I acquired in old engine. This is what I find on front of cam: Also attached a picture.
CD 310 310 - 06 900 BC 7R KK775 |
Liked 68 Times in 26 Posts
hello, have an old catalog of cam dynamics cams from what i gather, book ,shows, R310, 310-06 270 dur @ .050 .600 lift, ,030 lash,its for oval track racing hope thos helps
Liked 120 Times in 42 Posts
Based on the numbers Lobe separation should be 106 degrees, And a small base circle .900. for extra cam clearance to rotating assembly. Higher ratio rockers would give you more lift if needed.
Div 3 Sales, Service and Tech for many manufacturers |
Thanks for the info Gentlemen .
Any ideas on what lobe center it should be installed at? |
#5 | |
Liked 48 Times in 44 Posts
Rules of Thumb if any: Street car, install it advanced 4 degrees So if LSA=106, use ICL=102 Race, install it straight up 0 advance So if LSA=106 use ICL=106 From there it depends on the car, weight, gear, airflow, cam size. That's a pretty big cam so I'd guess ICL=102 but really just have to try it. |
