Old 08-23-2008, 05:07 PM   #18
Lynn A McCarty
Lynn A McCarty's Avatar
Default Re: GT/AA Class War At Indy
Originally Posted by Dyno View Post
Hemi S/S heads and blocks: Lynn, I do not know what you have looked at, but I have a set of NEW Mopar stock hemi heads sitting on the bench and they look just like the 68 heads next to them. After they are finished they may not look the same, but have you seen a S/S small block or LS prepped legel head, they do not look much the same either. The newer hemi blocks add an additonal 60 pounds to the front of the car. If you deck a new hemi block much more than .350, you end up with a very thin deck which can crack and not seal. The stuff the SS/AH guys are running are nothing like the hemi prostock stuff. Dyno
Dyno you gotta look a little deeper. The old stock heads weighed like 58 lbs, I think is the number (getting old CRS), the new heads are substantially heavier like 72 lbs. That extra cast iron is in the porting areas.
What is the old axiom for porting? It is hard to port where there is water.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
