Old 03-01-2011, 03:14 AM   #1
randy isaac
Default flow #s
for a sbc 041 head ( s/s ) just need to know what a good flow number is to see if i am at least in the ball park.
well over 200 veiws now...nobody willing share a little info??
randy isaac is offline   Reply With Quote
Old 03-02-2011, 08:06 PM   #2
RICK W
Default Re: flow numbers ?
I would like to know how much air flow to make 600 plus hp with 041 heads
RICK W is offline   Reply With Quote
Old 03-03-2011, 10:22 AM   #3
pemracengine
If you don't have 260cfm @28" you are not close. And $5000.
pemracengine is offline   Reply With Quote
Old 03-03-2011, 09:31 PM   #4
Stocker
257, 597,hp. 485 lb.tq.
Stocker is offline   Reply With Quote
Old 03-04-2011, 02:30 AM   #5
randy isaac
Thanks Stocker.
Old 03-04-2011, 06:39 PM   #6
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
You might do better asking if someone would PM you some of that info....
2894 STK
Old 03-05-2011, 03:29 AM   #7
randy isaac
any info sent in a pm would be good too. thanks for the suggestion.
Old 03-05-2011, 01:50 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
There is more to getting that power level than a peak number.
I can show you the flow numbers from 2 different heads and one has a higher peak number, but the head with the lower peak number makes a lot more power. I have the dyno results, too. One head combination kicks the others butt by having a much higher average from .100 to peak. There are some programs that will give you numbers that are available on the net. The key to that statement is: "will give you numbers". I like the idea of asking the question. Interesting answers.
Adger Smith (Former SS)
Old 03-05-2011, 03:00 PM   #9
Adger Smith
Oh!
Old 03-05-2011, 04:28 PM   #10
RICK W
So you should be able make good power if you have over 260 cfm with a good bottom end.
