#11 |
Liked 370 Times in 101 Posts
Mike Pustelny might have a Drag Pack Z-bar
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#12 |
Liked 54 Times in 24 Posts
Thanks Jerry. Why didn't I think of that. I'll shoot him an email.
How's thing's with the CJ?
Todd Gross 3323 FS/E,F |
#13 | |
Liked 888 Times in 239 Posts
I really didn't make any final patterns of the clutch setup since it was refined over a few weeks of building. Here are a few pictures to give you an idea of how I did Eric's DragPak. The sleeve is bushed and is welded thru the frame rail and the supported at the bellhousing . I'm looking for a better picture of the bellhousing end . You will have to fabricate a custom shifter mount and longer linkages. The left side of the tunnel will also need work to clear the linkage .
#14 |
The sleeve is bushed and is welded thru the frame rail and the supported at the bellhousing . I'm looking for a better picture of the bellhousing end . You will have to fabricate a custom shifter mount and longer linkages. The left side of the tunnel will also need work to clear the linkage .[/QUOTE] Thanks Tom. I appreciate the pictures and description. I could tell before that it's going to be complicated to switch to mechanical linkage...and it is. Definitely not a "bolt it" operation. Happy New Year!
#15 |
Is that a stock small block layout bellhousing on the dragpack?
#16 |
It is a stock SBM (LA) bolt and dowel arrangement, but you can get a bellhousing with left or right starter locations. Right side starter helps with steering shaft clearance.
#17 |
Im more worried about the fork location, i dont have my headers at the moment. Is the fork ok in stock location
#18 | |
The basic location is ok. ....Just needs a little more length and a straighter line out of the bell and I prefer to have a direct link instead of a push pin. These are MR2 Race Cars headers for the DragPak 360 shown in my previous pictures
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 12-31-2017 at 02:32 PM. |
#19 |
Liked 94 Times in 38 Posts
great pictures. did you make the shifter aluminum mounting plate? I want to beef up
mind. |
#20 |
Yes , 1/2" T6 . The picture was taken before I did the final trimming in front of the shifter . .... You don't realize how far back the driver placement is until you see stuff like the shifter.
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 01-02-2018 at 09:44 AM. |
