Check it out, pulley sizes are now part of the specs on the supercharged Mustangs.
http://www.nhra.net/tech_specs/engine/blueprints/FORD-08.rtf |
#2 | |
Banned
More important what DIA HAVE THEY BEEN RUNING AND WHAT DIA WERE THE RECORDS SET WITH GONE THRU TECH WITH?? LOOKS TO ME AS NHRA BOY'S DROPPED THE BALL BIG TIME N THIS ONE. The 57 fords had their dia llisted and as I remeber the Stick Shift was different than Auto had more Boost.
Liked 564 Times in 66 Posts
Also important to note is OEM pulley's only! No aftermarket! No playing with Belt and groove widths.
Bill |
exactly right Bill, it should also state that the tensioners must be OEM as well
Chad Rhodes 2113 I/SA |
Liked 11 Times in 4 Posts
Why should the tensioner have to be OEM?
Tim Kish 3032 SS/GS |
the OEM tensioner is spring loaded. Metco and others make tensioners that are positive acting, and act on a different place on the belt thus increasing boost by eliminating any slippage. The tensioner should at minimum have to be of OEM type (spring loaded) and should be in the stock location
#7 | |
Jeff Lee 7494 D/S '70 AMX |
Liked 380 Times in 147 Posts
Oh puulease! Then I'll run a belt soaked in belt dressing that has zero slip.
Man the hating is so obvious! I wish obama motors and fiat would hurry up and field their pony cars........ |
there is no "hating", i just know what the supercharged mod motors are capable of. I do applaud NHRA for specifying the pulleys finally.
Chad,
The pulley spec has always been there, just not published. However, I do not know if they were checking them. Bill |
