Old 03-15-2016, 01:05 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Re: SBC
Originally Posted by carl hinkson View Post
First of all very nice car you have. If you only have a 3.480 or 3.500 stroke there was no need for a .900 base circle cam, Those small base circle cams some times tend to flex with alot of spring pressure and lifters don't like that and the lifters hanging out of the bottom of the bore which is alot of pressure angle is not a good thing.
I think clearance wise you may have a little to much if anything.
I guess roll the dice those lifters will let you know if they are not happy.
What year are your cars ??
The aluminum rods LOVE the small base circle ( clearance ).
71 and 65 and thank you.
Old 03-15-2016, 01:26 PM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: SBC
I use aluminum rod in high end blower builds. NA engines I don't see any sense.
They eat up to much cam to rod clearance and cycle time is real short compared to a good steel rod.
carl hinkson is offline   Reply With Quote
Old 03-15-2016, 02:01 PM   #3
joespanova
Default Re: SBC
Different strokes for diff. folks I guess. 8800-9000 rpm.
I tend to not do what everyone else does.Thats why I don't bracket race and use a Nash 5 speed. And @3000lbs driver on board 9.30s to 40s nobody ever said I was slow.
Old 03-15-2016, 07:14 PM   #4
carl hinkson
Default Re: SBC
I guess so thats why I check lifter bore clearance and you don't. LOL
I would of used an Iron Eagle block rather then compromise cam to rod clearance and have to run a cam that looks like a pencil LOL. Or at least would have gone to a .904 lifter with a .810 wheel to reduce pressure angle.
It should be fun to drive !!!
Very nice cars though.
This article will help explain what you have going on.
http://performancetechnician.com/pdf...a-Lifter-2.pdf
Old 03-15-2016, 08:51 PM   #5
joespanova
Default Re: SBC
I hear you Carl , but its just a toy......I'm not trying to rewrite the record for anything........
Old 03-15-2016, 10:37 PM   #6
carl hinkson
Default Re: SBC
You sir have some very nice toys and thats an under statement
Old 03-16-2016, 07:30 AM   #7
joespanova
Default Re: SBC
Thank you Carl.
