Old 12-27-2017, 09:59 PM   #11
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: Hydraulic Thow out bearing
Mike Pustelny might have a Drag Pack Z-bar
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 12-28-2017, 08:36 AM   #12
Todd Gross
Liked 54 Times in 24 Posts
Thanks Jerry. Why didn't I think of that. I'll shoot him an email.
How's thing's with the CJ?
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 12-28-2017, 10:25 AM   #13
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Originally Posted by JMan View Post
Hey Tom,
Would you consider selling me a Z-Bar for my Drag Pak? That would save me a bunch of time in design work.
Sorry for not responding sooner ,got a lot going on.
I really didn't make any final patterns of the clutch setup since it was refined over a few weeks of building.
Here are a few pictures to give you an idea of how I did Eric's DragPak.
The sleeve is bushed and is welded thru the frame rail and the supported at the bellhousing .
I'm looking for a better picture of the bellhousing end .
You will have to fabricate a custom shifter mount and longer linkages.
The left side of the tunnel will also need work to clear the linkage .
Name:	IMG_1603 drag pak Z bar.JPG
ID:	43848   Click image for larger version
Name:	IMG_1608  z bar.JPG
ID:	43849   Click image for larger version
ID:	43851   Click image for larger version
ID:	43852   Click image for larger version
Name:	IMG_1618 z bar.JPG
ID:	43854   Click image for larger version
Tom Goldman is online now   Reply With Quote
Old 12-29-2017, 08:42 AM   #14
Todd Gross
.[/QUOTE]
Thanks Tom. I appreciate the pictures and description.
I could tell before that it's going to be complicated to switch to mechanical linkage...and it is.
Definitely not a "bolt it" operation.
Happy New Year!
Todd Gross
3323 FS/E,F
Old 12-31-2017, 11:55 AM   #15
Plymouth1969
Is that a stock small block layout bellhousing on the dragpack?
Plymouth1969 is offline   Reply With Quote
Old 12-31-2017, 12:24 PM   #16
Todd Gross
It is a stock SBM (LA) bolt and dowel arrangement, but you can get a bellhousing with left or right starter locations. Right side starter helps with steering shaft clearance.
Todd Gross
3323 FS/E,F
Old 12-31-2017, 12:35 PM   #17
Plymouth1969
Im more worried about the fork location, i dont have my headers at the moment. Is the fork ok in stock location
Old 12-31-2017, 02:28 PM   #18
Tom Goldman
I made a custom fork using the inner part of the stock type fork for the one I built .
The basic location is ok. ....Just needs a little more length and a straighter line out of the bell and I prefer to have a direct link instead of a push pin.
These are MR2 Race Cars headers for the DragPak 360 shown in my previous pictures
Name:	IMG_1598 resize.JPG
Old 01-02-2018, 08:29 AM   #19
stock1080
Liked 94 Times in 38 Posts
great pictures. did you make the shifter aluminum mounting plate? I want to beef up
mind.
stock1080 is offline   Reply With Quote
Old 01-02-2018, 09:42 AM   #20
Tom Goldman
mind.
Yes , 1/2" T6 . The picture was taken before I did the final trimming in front of the shifter . .... You don't realize how far back the driver placement is until you see stuff like the shifter.
