Old 12-23-2021, 09:49 PM   #28
B Parker
Liked 2,336 Times in 464 Posts
Default Re: New AHFS
Originally Posted by west coast View Post
Steve if we adjust the indexs that affects everyone, doesnt fix underrated combo's. Steve do you think my car is under rated for a fox body mustang since you owned one years ago?
Barry I see you ran more than -1.00 under 3 times this last year. Do you consider your car under rated? Yes i went -1.17 under at Boise and am damm pround of it, was not on kill did my normal routine warm up, no ice, my normal tune up and weight. I dont think my car is under rated. Look at other foxbody mustangs only a few others are fast.
Let me see if i can explain this to you with this example then you tell me what you think.
So a 70 camaro looks like it can A,B,C. You are running A. So when a 2015 camaro get some more HP and cant run B anymore they will be in A with you.
Can you run with one of these?
Do you think it is an under rated combo?
Would you go to B to stay away from them?
Barry I am very much like you, I am always thinking of new ways to make my car go faster. I work on my stuff to make it fast. I run the test day before the divisional race and put more runs on it that day than I do the rest of the weekend. Most test days I have plans on what to test and usually make over 10 runs that day.
James you should be proud of that run. It's a he## of a pass. No, I don't think you should get HP. Just wanted to point out to you that a lot of cars under good conditions can run close to or faster than 1.20. Take a look at the 1970 402/375 hp Nova. Now rated at 415. Just because of a heads up run in good air. Should the car be rated 15 HP more than the 1970 Camaro. This change is going to make it easier for any combo in a popular class to get HP not just the underrated ones. The 2015 Camaro's are faster than my car. There are a lot of A/SA cars in Div one. If I catch a few of them during the year I could end up getting HP long before the 2015 Camaro's putting me even further behind. BP
