Old 11-19-2012, 10:13 PM   #13
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Default Re: Aftermarket Cranks
Originally Posted by Rusty2211 View Post
Larry,
The rods are not custom length?? The center-to-center is the same as factory FE rods? I'll give you the fact the the rod is probably more reliable than the bigger rod end, but that's about it. When there are E/SA Mustangs that can run 10.00 at 3000' at Indy, I think you are barking up the wrong ladder.
Rusty
Rusty,
What E/SA Mustang might you be referring to? I only remember one at Indy in E, but it's wasn't the one that can run 10.00's in 3000 ft. of air. Care to elaborate on your scientific findings?
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
