#11 | |
Liked 100 Times in 45 Posts
If your car burns to the ground with a diaper on it shame on you. You say the diaper has an absorbant pad.Do you know for a fact it will absorb 5-6 qts. of oil.Also there's the possibility if you crack the block bad enough now you'll also have to deal with water. And what if you have a diaper on the car and oil/water still spills on the race surface?What then? Do you ask the manufacturer for a refund? Let's go back to getting the run away HP factors back in line.
Former NHRA #1945 Former IHRA #1945 T/SA |
